91 cadilac sedan deville will not start
Old 09-17-06, 06:06 AM
W
I have a 1991 cadilac sedan deville with a 4.9 engine, pulled car into driveway and cut off, next morning car would not turn over, checked battery, battery ok, put jump starter on selenoid, turned on key in run position and car will turn over but will not start, car will not turn over useing key, replaced ignition switch, not tumbler, but still will not turn over, checked fuseable link, checked starter relay, can feal relay click when trying to start with key, don't know where to go from here, would appreciate any help.
Thank you, Wambam.
Old 09-17-06, 04:47 PM
C
I would check my ignition system , including the timing.
Old 09-18-06, 05:09 AM
W
1991 cadilac will not start
How would the timeing keep the engine from turning over with the key, have checked all the ignition I know how to check, including replaceing the switch. there is something I am missing in checking the ignition, what i realy need is a pocedure in checking the ignition sys. I know it is something simple just can't lay my hands on it, my repair manual is no help, someone told me there is an ignition modual but don't know where it is or how to check it if i find it.
Thans Again, Wambam
