Where does vacumn line go for blower controls?
Old 09-17-06, 07:44 PM
foxbat5150
While driving home in 96 Monte Carlo, A/C stopped blowing from dash vents and started blowing from defrosters!!!!!!!!!
Found thin vacumn line from firewall flopping around, but can't figure out where it goes!
Thanks!!!!!!!
Joe
Old 09-18-06, 05:41 PM
Received 2 Votes on 2 Posts
If I understand correctly, the tube is loose near the firewall. Since they don't usually cut the tubes any longer than necessary, start checking under the dash in the firewall area for the mating tube. Just kind of define a circle where the tube could reach the air distribution box, and somewhere in that circle will be the mating part. When it came off, the door in the air box defaulted to defrost. putting the tube back should put you back in business.
