Dash lights?
Old 09-18-06, 07:23 PM
daniel55's Avatar
Dash lights?
I just bought this Dodge truck knowing it has some issues. I replaced the brake booster today, a big 40 min job. Next is to find out why I have the abs light on and the brake light and the check engine light. I will start with checking the lights and bleeding the brakes. I can check the pads along with the drumbs if you think the problem is there. Do I need to take this by and have the people at Auto Zone check it with there scanner?
By the way the brakes are now working afteer replacing the booster.
Old 09-19-06, 03:40 PM
HotxxxxxxxOKC's Avatar
I would do as you say first, check to make sure there is plenty of brake fluid, that can/will throw you a Brake light. Autozone should be able to pull any codes that may be there for the CEL and ABS. If no codes, you may have a bad cluster, or try disconnect the battery for about an hour to reset the modules.
