Cleaning battery cables improve starting?
Old 09-25-06, 11:24 AM
My car has been slow to turn over last couple of days. The battery doesn't seem to have a full charge.
I noticed some crud buildup on the battery cables, could it be something as simple as cleaning them?
1996 Acura Integra
automatic transmission
150,000 miles
recent complete tune-up.
Old 09-25-06, 01:32 PM
yes
Yes clean those connections use a wire brush or if you have posts on top they sell special cleaner brush. It might be other problems but it is a good start and has to be done anyway.How old is battery? 4 years is about all the life you get out of todays batterys.
Old 09-25-06, 02:27 PM
If it still starts slow after cleaning the connections, the crud may have worked itself inside the insulation which would require replacing the cables. Peel a little insulation back to check if necessary.
