1996 GMC Z71 5.7L hard start cold
Old 09-27-06, 03:28 PM
1996 Z71 GMC pickup hard starting cold when i get started starts right up after that i put a fuel psi gage on got 50 psi when key turned on what is the psi suppose to be when you turn on key or should i look in another area any help will be greatly appreciated.
Old 09-27-06, 04:54 PM
bnjguy
try a coolant temp sensor.
Old 09-28-06, 06:45 AM
before just throwing parts at it it would probably be a good idea to get it scanned for codes - they can monitor the ect with the scan tool rather than have you throw away money on a part that isn't required, could also be any number of things - ignition system, IAC, mechanical...good start is to eliminate the obvious
gm spec: key on 60-66psi for central SFI
56-62psi forthe SFI
good luck...
