96 neon no spark
Old 09-27-06, 05:26 PM
96 neon no spark
96 neon with a 2.0 sohc doesn't spark out of the back side of the coil, but the front does. new crank sensor, cam sensor, computer, coil ohms tested good, tried different coil, same problem, wiring to computer and sensors all have continuity, was running good but stalled and won't restart, has fuel pressure and injector pulse, good compression
Old 09-27-06, 07:23 PM
2 circuits in the ign coil.............should be 3 wires.........Power going in and ground coming out on 2 of the wires.........The ECM in this case is the "module" that controls the spark pulse..........and from the sound of it, it's only pulsing one circuit
