2002 pontiac fuel pump starting issue...
Old 09-28-06, 04:50 PM
mrblue's Avatar
starts fine, but once you apply the brake it kills the fuel pump. need some help on getting me down the road again.. it has some type of passlock security thing on it.. Using the factory key to start it, and it runs fine till you hit the brake or put in gear AND THEN YOU CAN HEAR THE PUMP STOP AND IT DIES EVERY TIME...... any type help would be appreciated as i cant even drive it to the shop.. I have disc battery once to see if that would help but nothing... PLEASE !!!!!
Old 09-28-06, 06:45 PM
HotxxxxxxxOKC's Avatar
Definetly sounds like an alarm issue. Usually this will happen if the car has a remote start installed. It prevents a thief from taking your car while the car is running without the key.
Have you recently got a new key? If so, it has to be coded to your computer in the car most likely. If not, then it's probably a bad alarm.
Old 09-29-06, 03:43 AM
mrblue's Avatar
thanks,, but its the factory key.. i am just wondering if there are any bypasses for it..
