Heater not keeping air warm
Old 09-30-06, 08:35 AM
2002 Chevy Blazer. The heater will start to blow warm air but as you drive in the cool air, the air inside cools down as well. Still a little bit of heat from it but not like it should be. The temp gauge stays at about 200 / 205 degrees. I've replaced the thermostat but no change. One person has said that there might be a valve or sensor that might be preventing the circulation of the warmer coolant.
Old 09-30-06, 12:52 PM
Sounds like a plugged heater core to me...pretty common I think...flush it out good with a garden hose
Old 09-30-06, 02:34 PM
Received 2 Votes on 2 Posts
With only four years on it, I doubt that the heater core is plugged. I would be looking for a heat valve or sticking duct door which may be blending too much outside air with the heated air.
Old 09-30-06, 10:40 PM
ever worked on something with dexcool? have seen them plug up with dex-mud in under 2 years old
Old 10-01-06, 06:51 AM
I would put one of those rad flush kits and mount the garden hose connection the the upper heater hose where it is the highest.
I have had trouble with air in the upper heater hose in the past.
I now put the garden hose connection as an easy way to bleed the air as well as flush the system.
Air will go to the high parts of a system and is compressible and cause weird things to happen.
