1994 Ford Explorer Oxygen sensor location
1996 Ford Explorer 6 cyl. 4wd Oxygen sensor location
I have the engine light on and was told it is the oxygen sensor. Can someone tell me where it is or if there is a diagram of it's location I could get? Also, Is there more than one?
Here you go:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0e/2f/99/0900823d800e2f99.jsp
Just curious, but did whoever told you it was the O2 sensor discover that by reading the check engine codes or are they guessing?
There should be 4 ............2 on each side one before and one after the catalytic convertors.....HOWEVER!!!!......If you're getting multiple LEAN codes.........bank one AND two........Check all the vacuum hoses first. Ford is NOTORIOUS for vacuum tube connectors collapsing and perforating...........Pay specific attention to the PCV hose
