A/C condensation 1993 Jeep Grand Cherokee
Old 10-01-06, 01:20 PM
hey guys,
i need some advice. i know there is a water collector for A/C condensation on my 1993 Jeep Grand Cherokee. But, mine is plugged up. Isn't there a way to unplug the A/C evaporation collector's expulsion line? After all, it is only water coming in.. and I can see it drip from a coolant line into the car.
I believe what I want to access is in the motor, not the interior. There is a firewall in the way, and I do not want to remove any of the asbestos covering. I was told by someone at the dealership, that I needed simply to poke something through the overflow drain...but, I can't find it. HELP
her5th
Old 10-01-06, 02:06 PM
the_tow_guy's Avatar
Received 34 Votes on 27 Posts
Best wasy to do it is going to be with the vehicle either on jack stands or ramps so you can safely crawl underneath. After that just look for a piece of hose hanging down from the fire wall on the passenger side. About the best way to clear it is with a shop vacuum.
Old 10-01-06, 04:00 PM
yep
yep a shop vac or a very long zip tie or tie wrap the kind you use to zip wire bundles.
I used to use wires but with them you could cause damage if inserted to far.
