Power Steering and Oil Sensor
Hello,
1)
I have a 1999 Chev. Z-71 PK w/ the small V-8 automatic. The problem that I am having is that the steering is hard to turn to the right but turns to the left normally. I've checked the fluid level and that is fine. I put the PK on jack stands and can turn the wheels to the righ w/o any difficulty. Where should I start?
2)
Also, on a side question. The same PK has a low oil level light that is on and the oil level is fine. I had to replce the starter and suspect that I may have damaged a sensor unit. Is the oil level sensor going to be the beige plastic "thingy" below the starter going into the oil pan or is it the wire that I had to disconnect above the starter that goes into the block? ***I'm hoping that it's the lower one--I used my yearly allowance of bad language taking that starter off*** If it is the beige thing does it just screw out?
Thanks in advance,
John
1)
2)
Thanks in advance,
John
There is no rack and pinion on this truck. I seem to have pressure from my power steering pump since it will turn left with ease and am leaning towards the steering gear box. Any thoughts?
