1996 toyota Camry
Old 10-02-06, 02:07 PM
Unhappy 1996 toyota Camry
hi guys put a new fuel filter on and it still want start we took the top of fuel filter off and it is shooting out gas so it appears that the fuel pump is working but it just want start we took off the desibter cup off and it is turning so i don't think that it's the timeing belt all help is needed thanks
Old 10-02-06, 02:52 PM
the_tow_guy's Avatar
Received 33 Votes on 26 Posts
Didn't realize you had a no-start condition, Blackie; just thought you were replacing fuel filter. Time to narrow it down. Pull a plug wire and set so that end is close enough to a ground for a spark to jump. Have someone crank it and watch for spark. Post back what you find. Would be helpful if you could have it scanned to see if any codes are stored, but will be difficult to do with it not running.
Old 10-02-06, 03:53 PM
Unhappy coil wire is firing
coil wire is firing replaced spark plugs and they are firing and wires are working great also thanks
Old 10-03-06, 04:25 AM
Unhappy it went dead going down road
it went dead going down road to work it just died pulled it home put all this stuff on it and it still want start any ideas
thanks
Old 10-03-06, 05:47 AM
Got fuel, got spark, got rotation. Scratching my head again. The Camry's are pretty bulletproof so I'm at a loss unless maybe you jumped a tooth or two on the timing belt which isn't very likely. How many miles and is it a 4 or a 6? At that age a broken timing belt would certainly be a prime suspect, but you've already checked that.
Old 10-03-06, 06:09 AM
Unhappy 157308 miles
it has 157308 miles and the timing belt was changed in 2001
we are going to use quik start this moring to see if it will start if it does i guess it could be the fuel pump what you think
thanks
Old 10-03-06, 06:46 AM
Always a possibility, but like most stuff on the Toys they're pretty reliable.
Old 10-03-06, 07:47 AM
fuel reg.
what about the fuel reg. do they give much trouble
blackie
Old 10-03-06, 09:47 AM
Again, pretty reliable. Only way to be sure is with a pressure gauge.
