1991 Taurus front end and water pump
Old 10-04-06, 06:24 AM
Hi,
I have a couple of problems with my Taurus 3.8l. I need to replace the left front tie rod end (I would take it in for alignment afterward) and the water pump. I was thinking of doing these myself, though I would probably need to buy a manual first to make sure I do things in the right order.
My question is...are these repairs exceptionally hard? Do I need any special tools? I changed the water pump on a Ford Escort one time that required removing the timing belt and I don't want to get in to something like that again. Thanks for your help.
Old 10-04-06, 06:47 AM
the_tow_guy's Avatar
Received 39 Votes on 31 Posts
Well, your water pump is external, unlike those that are run off the timing belt. It's not a lot of fun because the space between the engine and the side of the engine compartment is pretty tight. The procedure is on this page:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0b/f5/c6/0900823d800bf5c6.jsp
Old 10-04-06, 07:20 AM
Thanks for the link! You wouldn't happen to know if the front end part is called something besides a tie rod end? I don't see that listed on the web site you gave me. Maybe it's part of an assembly?
Old 10-04-06, 12:40 PM
Check here:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/0c/13/03/0900823d800c1303.jsp
Old 10-04-06, 12:50 PM
Thanks! I appreciate the help.
