need advice
Old 10-04-06, 09:14 AM
E
need advice
I have a 95 subaru legacy awd wagon that starts most of the time, but sometimes the key turns and nothing happens. I have replaced battery, cables, starter, ignition and still having trouble. It will work for 3 days and then not, can be cold engine or hot. Anyone have any ideas? local shadetrees are stumped. I can't afford a dealer . thanks
Old 10-04-06, 10:27 AM
HotxxxxxxxOKC's Avatar
When you say nothing happens, do you mean the engine does not turn over or no lights, sounds, etc?
Old 10-04-06, 11:44 AM
do you have a killswitch installed ? (it can weaken the + to your relay)
check starter-relay and starter-solenoid.
there may be no ground on starter relay due to ECM problem.
Old 10-04-06, 03:56 PM
E
need advice
it clicks like the battery is dead. but only once. today I moved the pulleys and it started, a local said there could be teeth out of the flywheel, that's a big job isn't it , replacing the flywheel?
Old 10-05-06, 11:48 AM
sometimes just clicks, sometimes starts ?, check your bat terminal connections for good conductivity
