toyota inertia switch
Old 10-05-06, 10:13 AM
Unhappy toyota inertia switch
1996 toyota Camry inertia switch some call it the fuel shut off does anyone know where this is at all help needed thanks
Old 10-05-06, 11:02 AM
the_tow_guy's Avatar
Received 32 Votes on 25 Posts
To the best of my knowledge you don't have one.
Old 10-05-06, 11:09 AM
dog
we have checked everything the timing is right it is getting fuel to the filter but seems that is as far as it gets any throughts
Old 10-05-06, 02:31 PM
Received 2 Votes on 2 Posts
So what happens with the filter removed? Do you get a trickle or a gush when you switch the ignition on? If it's a trickle or nothing, I would first check the fuel pump fuse, followed by the fuel pump itself.
Old 10-05-06, 03:55 PM
resets itself
Fuel shut off is self resetting.
Old 10-05-06, 06:58 PM
Where's it located, MV; I'm not familiar with it?
Old 10-06-06, 02:52 AM
not sure
Not sure but as per owners manual it says (quote) The fuel shut off system stops supplying fuel to the engine to minimize the risk of fuel leakage when the engine stalls or an airbag inflates upon collision.To resart the engine the engine after the fuel pump system activates turn the ignition switch to ACC or LOCK once and start it.
It also says to check for fuel leak under car first. I guess it must be all electronic.
Old 10-06-06, 10:59 AM
Red face fuel pump fuse
hi where is the fuel pump fuse at on this thing lol
thanks
Old 10-06-06, 03:11 PM
OK check here
Ok this is for a 2000 model Corolla but I bet it is the same Toyota is good at keeping things like that simple.
Under the hood behind the battery are two fuse boxes Look in the big one for a 15A fuse number 11 on my 2000.
