Help fixing tie rod ends
Old 10-06-06, 06:04 PM
i have a 1995 saturn sc2; 4-116; 1.9L SOHC
i need my left and right outer tie rod ends replaced.
is this a hard job? expensive? i don't know much about cars. need a little advice.
many thanks.
Old 10-06-06, 06:26 PM
the_tow_guy's Avatar
Received 38 Votes on 30 Posts
Pretty easy job, but takes a little precision so that the new ends are close enough to the correct position to safety drive the car someplace to have the alignment done afterwards. Also it sometimes requires a special tool.
Here's the procedure:
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/19/ab/47/0900823d8019ab47.jsp
The special tool shown isn't always necessary. Somtimes a good smack with a hammer on the end of the threaded portion, after removing the cotter pin and nut, will pop it loose from the steering knuckle.
Old 10-06-06, 07:03 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
Actually if you whack the steering arm where the tie rod end goes through, it will be easier than whacking the threaded end. (at least in my experience). Been doing it this way for 30+ years.
