How to Decode Check Engine
Old 10-14-06, 12:44 AM
rdn2113's Avatar
A while back I scanned a post that explained how to decode a Check Engine manually without the aid of a decoder. I used the process once at least a year ago and it worked well. Unfortunately, I forgot to write down the steps.
I have a 1994 Plymouth Grand Voyager LE, 3.8L, 6 cylinder. I noticed that when I drive for more than four or five miles above 55 mph, I get a Check Engine.
There are no other symptoms - the car is running great.
I'm suspecting an EGR issue but I would like to confirm. Can anyone refresh my memory on the manual process? I know it involves turning the ignition on and off a number of times and then counting the check engine light flashes, but I don't remember the exact sequence.
Thanks in advance!
Old 10-14-06, 07:35 AM
HotxxxxxxxOKC's Avatar
Here ya go:
http://www.troublecodes.net/chrysler/
Turn the ignition key ON,OFF,ON,OFF,and finally ON again(ENGINE NOT RUNNING)
The codes will start to flash on the POWER LOSS or CHECK ENGINE light.
FLASH,pause,FLASH,FLASH=code 12
Here are the code link:
http://www.troublecodes.net/chrysler/88-95_30333538.shtml
Old 10-14-06, 07:24 PM
do these steps work on all vehicles, i have a 2001 altima
Old 10-14-06, 07:41 PM
You have a OBDII output on your Altima. Bring it to Autozone and they will tell you the codes for free.
Old 10-14-06, 11:18 PM
rdn2113's Avatar
Thanks for the help HotinOKC - I appreciate it!
Rick
