interior not very warm in pickup
Old 10-15-06, 09:24 AM
my heater doesn't seem to blow much heat already changed the thermostat any help
Old 10-15-06, 09:26 AM
HotxxxxxxxOKC's Avatar
Received 1 Upvote on 1 Post
Are you leaking any antifreeze? If not, you can try and flush the radiator system/heater core out. Also, there is a mixxing control valve within the dashboard. If this is going out, you will not get the hot air you need. Basically, the heater core produces the heat, and a fan blows across it and then the air goes into your vents. If the valve is broke, you will get little or no heat.
