Timing Belt squeaks
Old 10-15-06, 06:00 PM
B
Timing Belt squeaks
Hi. I recently replaced the timing belt on my 1994 Plymouth Voyager 3.3L minivan. It is now increasingly squeaking, and the squeak is coming from the pulley closest to the windshield. Is there something I can apply to the belt or the pulley to make this stop, and if that doesn't work should I replace the belt tensioner? Hopefully I can eliminate the squeak w/o having to take the belt off because it is very difficult to remove it from this vehicle.
Thanks,
Babbabooey
Old 10-15-06, 06:11 PM
HotxxxxxxxOKC's Avatar
Hopefully it's not your TIMING chain as you say, since they are internal (engine). If your accessory belts are making noise and you recently replaced them, then it could be a bad belt tensioner like you said. Check into that first. Observe the other pulleys as well, make sure they are not wobbling.
Old 10-16-06, 02:18 PM
B
Oh - I meant serpentine belt.
