1996 Chevy C1500 starting problems
Old 10-16-06, 12:34 PM
My truck won't start without starter fluid but once it's running it runs perfectly fine. It idles fine and doesnt chug. It turns over fine, its not a problem with the battery or starter. I can hear the fuel pump on and I just replaced the fuel filter. So I'm thinking that it may be a bad TBI unit?
Old 10-16-06, 12:59 PM
bigfred's Avatar
You probably already did this, but this is my thought.
I would check each vacuum line because a leak in one of them could cause this problem, plus it's pretty easy to do. Since it could be a hiddlen vacuum leak somewhere along the line or at it's destination, I'd plug them one at a time (at the intake manifold) and crank the engine briefly to see if plugging one results in the engine starting.
