clean engine
Old 10-18-06, 01:32 PM
New Member
clean engine
What is the best way to clean an engine so I can look for oil leaks...I have a power washer....Any ideas
Old 10-18-06, 01:44 PM
HotxxxxxxxOKC's Avatar
I usually spray the motor down with some engine degreaser, let it sit for about 5 minutes, then take a pressure washer to it. It does the job good. The only way to get it really pretty is to do what I said, and then use a pressure steamer. Thats not really necessary though. Just cover up your air filter if it's exposed to the engine bay.
Old 10-18-06, 03:17 PM
gunk
Get some engine degresser and follow directions on can.Try to keep all electrical connections out of the water.Use plastic bags or you can use foil since it will mold around the connection.
Old 10-18-06, 05:19 PM
A pressure washer will do a good job, just be sure you know what can be washed with pressure, what can only handle a little moisture and what you need to keep dry.
No fun to have a nice shiny clean engine if it won't start
Old 10-18-06, 07:19 PM
can of degreaser and power washer is the way to go
watch out for distrib cap and alternator, try to stay away from them
good luck
