P codes 0125, 1130, and 1135 for Toyota Tacoma
Old 10-19-06, 05:08 PM
Post P codes 0125, 1130, and 1135 for Toyota Tacoma
Hi
I have a Toyota Tacoma 2000 2.7 4X4. I scanned and recieved codes p0125, p1130, and p1135; cleared the codes, but the codes keep reappearing. The check engine ligth will trun off when the temperture out doors is over 80 degrees.
I need advise to what the possible solution(s) to these problems are. The vehicle fuel econamy is decreasing.
You may email me at [email protected] if you prefer
Thank you for your help.
Last edited by DIYaddict; 10-19-06 at 07:10 PM. Reason: Email address removed/This is for your protection and to prevent your email from being filled with spam.
Old 10-19-06, 05:13 PM
C
P0125. ECT Sensor. P1130. Swirl Control Valve Control Solenoid Valve. P1135. Intake Valve Timing Control, RH Bank 2
Old 10-19-06, 07:20 PM
HotxxxxxxxOKC's Avatar
You just can't clear the codes. You have to fix what is wrong, then clear them if they don't automatically go away. Bank 2 sensors (O2) will cause most of those codes.
Old 10-19-06, 08:14 PM
All 3 of the codes indicate a malfunction in B1S1 air/fuel ratio sensor. (what used to be an O2 sensor). There are a few tests you can do to make sure, but I would feel comfortable recommending replacing that sensor and clearing the codes.
Hope this helps.
John
Old 11-03-06, 11:11 AM
Still have problems with p code 1130
I change the O2 sensor after the cat. and reset the computer. Within 10 minutes the check engine light came on and the p1130 code was read. Any other shuggestions out there?
Old 11-03-06, 02:30 PM
Exclamation
You should have replaced both or all the O2 sensors. It's probably the one that you didn't replace. These sensors are pretty expensive most of the time too. Also, the P1130 and 1135 codes will throw the 0125, so ignore the 0125. The 1130 code is Bank 1, sensor 1.
Old 11-03-06, 02:36 PM
^ These are not the right narratives for the code.
P1125 Throttle Control Motor Circuit.
P1130 Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 1)
P1135 Air/Fuel Sensor Heater Circuit Response. (Bank 1 Sensor 1)
