12v oulets
Old 10-20-06, 05:05 PM
Question 12v oulets
I have a '96 Chev.1500 Silverado that has a factory installed cluster of of 3 12v power outlets, one on top that's open for the lighter and 2 others beneath with spring covers on them. The open one works fine but the two below don't. I checked for a blown fuse in the fuse box under the hood, but found none. Is there another set of fuses that I'm missing that could be the culprit? Or is there another possible cause? Thanks for any feedback.
Old 10-20-06, 05:33 PM
HotxxxxxxxOKC's Avatar
There should be a fuse panel inside the cab. Usually drivers side dash area. You usually have to open the drivers door to pull the panel out. There should be a fuses in there that should solve your problem. Also, check those receptacles for anything that may have blown them. I remember it took me an hour of putting in new fuses to figure out there was a dime down in the power outlet wich was blowing them.
Old 10-20-06, 07:36 PM
I will take another look under the dash. I didn't see it the first time I looked. Will followup after I recheck there. Thanks.
Old 10-20-06, 08:27 PM
It may not be "under" the dash. In my cars, theres a panel on the outside part of the drivers side dash. It should tell you in your Owners Manual.
I think, but not sure, the fuse in question is fuse 7 25amp under the hood. Also check for a tripped circuit breaker.
Old 10-21-06, 06:20 AM
This may sound silly, but did you check the other 2 with the vehicle running? Sometimes the manufacturer will supply one with power, with key off, but the others only get power with engine running or in accessories position. Didn't see where you stated trying it with vehicle running, so thought i'd better ask.
Mike.B
Old 10-21-06, 08:20 AM
Mike B., for the record I did try them with ignition on and off with no success.
HotinOKC, the fuse panel was exactly where you said.
jeff67, you were spot on. It was indeed a blown 25amp fuse in slot 7. Problem solved.
Much obliged to all of you responders! I deeply appreciate your kindness in replying.
Have a blessed day.
