Abnomral Sound after starting GMC 1991 A/C
Old 10-24-06, 07:03 AM
Smile Abnomral Sound after starting GMC 1991 A/C
My vehicle's details are:
1- Engine size is 454, 7.4 L, V8
2- Model 1991
3- Type GMC 2500
It is working fine. However, every time I started the A/C an abnormal sound is heared like "hummm". several checks were done and did the following:
1- Replaced the A/C compressor
2- Replaced Auto belt tensioner
3- Idler pulley bearing
4- Replace belt
5- Replaced broken mounting bracing of Power steering pump
6- Replace broken power steering pump and alternator bracket at the bottom support
However, the problem still exists. Please share your possible solutions and advices that will help me fix it.
Many thanks in advance.
Old 10-24-06, 08:18 AM
HotxxxxxxxOKC's Avatar
Look at the following:
1. Inspect Water Pump - Main shaft seal on water pump has failed causing shaft to squeel or grind.
2. Inspect Radiator Fan Motor - Worn or damaged cooling fan motor or circuit.
3. Inspect Alternator Bearing -Worn or damaged bearings
4. Inspect Fan Clutch -Worn, loose or faulty fan clutch.
Also, it's been so long since I replaced a a/c compressor, but, did it come with a new clutch? If not, check that out as well.
Old 10-24-06, 03:23 PM
You have spent a lot of money on this and still have the problem, which may not even be a problem, just an annoyance. During a cold start, there are often things in the emmissions control system that are at half settings(by the computer), that may flutter. Most of these noises go away as the engine warms up, is this your case??? If yes, stop throwing your money away, or send it to me. How many miles on this vehicle??
