engine and trans needed
Old 10-24-06, 11:09 AM
Exclamation engine and trans needed
I have a 95 caviler, that has a bad engine and trans. I am looking for a good used set in the Atlanta area, is there any out there.
Old 10-24-06, 12:06 PM
Q
Lightbulb
I've had excellent results from EBay, but not for big stuff like
engines, etc. Still -if the price is right & you can either go get it or have your pal Darrell get it with his pickup......
Old 10-24-06, 01:24 PM
nightowlpunk's Avatar
You might want to call local junkyards, they do normally offer some sort of warranty, or you coulod try www.uneedaprt.com .
Old 11-01-06, 09:16 AM
Yours should be easier to find since I called 12 junkyards and only 2 of them had it because VW changes the transmission just enough so you cannot put a different year more than by one or two.
Old 11-01-06, 04:29 PM
K
Thats strange engine and trans. You did not state what model. If it is just a simple 4 cyl they are a dime a dozen. If it is a quad 4, you have an expensive problem. 1995 was the last year for that drive train but there are millions of simple 4's made. Those transmissions last for ever too. Still do not understand why both.
