1999 jimmy sle 4x4
Old 10-28-06, 05:38 AM
dave b's Avatar
New Member
Unhappy 1999 jimmy sle 4x4
when i drive it it makes a like a huming sound just stared
Old 10-29-06, 10:49 AM
need more info, one mans "hum", is another mans "grind"
Old 10-29-06, 11:37 AM
HotxxxxxxxOKC's Avatar
Definetly need more info, like where it's coming from, does it do it only when driving, etc?
Old 10-30-06, 05:35 AM
dave b's Avatar
New Member
cant tall where it comes from yes humes only when i drive it the faster i go the lounder it getes maybe tiers gessing
Old 10-30-06, 08:48 AM
does it do it all the time or only when accelerating?
Old 10-31-06, 05:12 AM
dave b's Avatar
New Member
when i accelerat it getes lounder when i slow down to stop it goies a way
Old 11-04-06, 05:09 AM
dave b's Avatar
New Member
1999 jimmy
Old 11-04-06, 02:33 PM
chevyastro4x4's Avatar
my van did that and it turned out to be wheel bearings and rear dif gears
Old 11-04-06, 11:09 PM
Wheel bearings
I've got the same vehicle same year and it sounds like your about due.
Be careful if it is bearings, watch the parts you buy i've replaced 3 already 2 on my drivers side alone only because the SKF ones i bought had a bad batch or the bearing was a one off defect. But the first time it only lasted 5 months, different maufacturer now seems to be fine. Hard to tell sometimes which side the noise is coming from ,a good rule of thumb is to put your feet flat against the floor while driving and you can usually feel, obviously someone will have to drive while checking the passenger side, but it works you can feel the difference depending on how advanced it is.
Old 11-07-06, 04:55 AM
dave b's Avatar
New Member
bearing
yep it is the bearing thankes for the help
