1999, ford zx2 problem
Old 10-30-06, 06:11 AM
my kids car. she told me the heater and ac blower just stoped working. does anyone know if there is a fuse i can check and where it is. I did check the fuse box under the dash, the ac fuse is fine, but there is no listing for the heater or a blower. what can i do?
Old 10-30-06, 05:23 PM
Probably a bad resistor block
My Chilton book is hard to understand, but there may be a circuit breaker for the blower motor. If present, it is in a power distribution box above the fuse panel. It is one of two kinds of circuit breakers. One automatically resets after a given amount of time. The other will not reset until the fault is corrected.
You may want to examine the resistor block for the blower motor. They are prone to corrosion problems. I just had to replace mine - from a 98 ZX2 - for $14. It is located in the passenger foot well right under the blower motor. I found a mess of corrosion and burned wiring.
If you need further help, try the folk on the following web site:
http://www.teamzx2.com/index.php?board=18.0
