Blower motor relay 95 olds 88
Old 11-01-06, 04:19 PM
R
Where is the relay located for the blower motor for the heat & a/c on a 1995 olds 88?
Old 11-01-06, 07:19 PM
G
Received 2 Votes on 2 Posts
I don't think it has a relay, but is connected directly from the switch. I'm sure that you asked for a reason. What problems are you having?
Old 11-02-06, 10:42 AM
R
The fan will not operate unless it is wired hot. The electronic heat & air control works properly, but there is no current to the fan unless wired directly to hot wire. Right now I have the fan wired to a toggle switch. I have changed the electonic a/c control but no help. The manual shows a blower motor relay in the electric schematic and speed resistor. GM says its mounted some where under the dash, NAPA has the relay but I can't find it anywhere.
Old 11-02-06, 10:54 AM
G
Best I can do is for an ' 88 Buick. Should be similar. It lists the low blower relay as being in the Component Center, right side of instrument panel, below the glove box. Hope this helps.
