starting problem in the cold
Old 11-01-06, 10:57 PM
starting problem in the cold with 92 corolla
my 1992 toyota corolla 182k has hard time starting in the cold morning what i should check and adjust to fix the problem Thankyou in advance
Old 11-02-06, 02:19 PM
Received 9 Votes on 9 Posts
The sensor that talks to the computer is the water temp sensor. It would signal extra fuel needed for the cold starting. It could be bad. That engine may or may not have the cold start injector. The mid 80's 4 cylinders do.
There's nothing to adjust on it.
Hope this helps,
Bob
Old 11-03-06, 04:50 AM
the_tow_guy's Avatar
Received 48 Votes on 38 Posts
Make sure your basic tuneup items are maintained - plugs, plug wires, dist cap & rotor, fuel filter.
Battery up to snuff, i.e. good fast cranking?
Old 11-03-06, 10:49 AM
R
If you live at a high altitude, you may need to adjust your choke.
