Ventilation--Jeep
Old 11-05-06, 05:41 AM
R
Ventilation--Jeep
Sirs:
1988 Jeep Comanche Pick-Up. Cannot direct air to dashboard ducts. Ventilation is now all directed to "defrost" and "floor" ducts. I have checked all vaccuum hoses and found no problems. This is a basic AC/Heat system without automatic climate control.
Any suggestion to troubleshoot system is appreciated.
Rebel
Old 11-05-06, 06:05 AM
Received 226 Votes on 201 Posts
Check the cable connections both on the lever on the dash and where it ends under the dash at the duct housing.
Old 11-05-06, 07:08 AM
HotxxxxxxxOKC's Avatar
This will happen when the air mixing valve within the airbox brakes. The air will revert to the default defroster mode. Only way to fix this is to get a new air mixxing valve. It's a pain in he butt to get to sometimes. Also, check your vacuum line goinging in through the firewall to the airbox.
