92 nissan sentra won't start
Old 11-06-06, 04:01 PM
Question 92 nissan sentra won't start
92 nissan wont start or crank , did load test on battery, tested ok!it does not crank at all.theres a red light blinking inside for the alarm. what would you check next ? is there a fusible link that can cause this? this is a 4cly. eng. thank u!
Old 11-06-06, 04:59 PM
HotxxxxxxxOKC's Avatar
Is this alarm light still on when you try to start the car? If so, they you have an alarm issue. Do you have the remote for this alarm?
Old 11-06-06, 05:57 PM
Question re 92nissan
yes but the alarm is disconnected from the battery .
Old 11-07-06, 02:52 AM
New guy's Avatar
On some of "aftermarket alarm", when you disconnect it from battery, you may also disconnect the starter circuit from ignition switch too.
Can you connect it back at the Battery and disconnect the connector at the alarm module and see if the light goes out and engine started, if not, the first thing that I'd do is get rid of that alarm and reconnect everything back to the orginal way and go from there.
Old 11-07-06, 05:43 AM
New Member
Post this question on www.nissanforums.com
under the Sentra section you'll get the correct response.
I sould suggest disconnecting both battery terminals for 15 mins and reconnect them and see if the car turns over.
Trackbacks are On
Pingbacks are On
Refbacks are On
