93 dodge dynasty won't start!!! help!!!!
Old 11-08-06, 10:54 AM
I was driving my car for about ten mins i pull into a gas station and turned the car off. When I turned the key it would not start ( I do hear the silinoid on the starter click )but it doen not crank. The lights and radio come on. but car won't start. check fault codes and recieved 45 Turbo boost limit exceeded (engine was shut down by logic module) ONLY ONE TIME. But I could not reproduce the code. I checked the codes again and I only got 55 (End of codes) I cleared out the codes, ran the test again and only got 55. Could it be the *STARTER* (it is cold out 48'F)?
Old 11-08-06, 03:54 PM
G
Received 2 Votes on 2 Posts
Turn on the headlights and watch them as you have someone try to start it. If the lights dim and go out, it's the battery. An internal short between plates can quickly wipe out a battery.
See if it starts with a jump. If so, it also points towards the battery.
