87 Honda Accord heater problem
Old 11-08-06, 04:10 PM
Not sure if anyone has any advice for me on this but my son has an 87 accord and the heater control doesn't seem to do much until you slide it all the way to the right to set it to HIGH. Then it blows full blast but there doesn't seem to be any middle ground.
Not sure where to look other than start peeking under the dash to see if something can be adjusted.
TIA.
Old 11-08-06, 04:47 PM
HotxxxxxxxOKC's Avatar
Your cheapest route maybe to get a new heater control unit (where you adjust temp,speed, etc) from a junkyard. If that doesn't solve your problem, then you may have to tear into the air box.
Also, does the controls work correctly for the A/C if he has it?
Old 11-09-06, 03:50 PM
No A/c
No A/c in this model.
So the heater control unit... would that be something under the dash attached to the back side of the dashboard controls?
Old 11-09-06, 04:12 PM
Try replacing the actual controller. The part that you adjust the temp on and fan speed.
Old 11-10-06, 04:28 PM
trip to the junk yard
Ok. I guess I'll take a trip to the junk yard and see what I can find.
Old 11-11-06, 11:32 AM
won't be alot of help but i have an 88 acord with the same problem. i have had no luck finding the problem. a friend said it could be something is blocking a door under the dash.
good luck
Old 06-03-07, 07:52 PM
blower motor resistor
This is one 'late update for the archives' but I was doing a search on 'accord' and found an old posting of mine but not the solution.
It ended up being the 'blower motor resistor' that sits at the bottom of the heater. Found one at the junk yard for cheap and it's worked ever since.
