86 nissan 720 pickup, Not getting fuel
Old 11-09-06, 06:27 PM
Unhappy 86 nissan 720 pickup, Not getting fuel
I have a 86 nissan truck 720 te old body style. Its throttlebody carbretor and its getting gas up to the carburetor but the injectors seem not to be spraying. Anyone know what my trouble might be? I have changed the carburetor, electric fuel pump, Filter.
Old 11-10-06, 07:31 AM
HotxxxxxxxOKC's Avatar
Run some injector type cleaner through. You might have a clogged injector.
Also, have you checked for spark? Remember, you need 3 things for engine start; Air, fuel and spark.
Old 11-10-06, 09:26 AM
New guy's Avatar
...and I though they were Fuel, Spark and Compression.
Old 11-10-06, 09:44 AM
Compression is overrated.
Old 11-10-06, 04:35 PM
A
check for power to the injectors with a testlight
Old 11-10-06, 06:24 PM
It's carborated, not fuel injected. Saying that, there is no power at ANY injector on a carb. Fuel is regulated by vacuum.
Old 11-10-06, 07:08 PM
A
if it is throttlebody like he says then it has injectors
Old 11-10-06, 08:54 PM
Yes, he got injectors, but not electrically controlled. I shouldnt call the injectors either, they are called jets.
Old 11-11-06, 04:11 AM
New guy's Avatar
+1, check the power to the injectors, look closely at the connector, most of the time , the terminals at the connector were pulled out a little bit.
Old 11-11-06, 08:15 AM
Am I missing something? He has a carb and tb. He shouldn't have any electronic fuel injection, just vacuum controlled fuel jets which do not use power.
Old 11-12-06, 09:15 AM
Its a throttle body and yes it had injectors. I put a test light on it and was told to turn the key on and the test light should light up the go out. I have power ion it if when the key is off
Old 11-12-06, 11:14 AM
New guy's Avatar
Look inside the Distributor, there's a crank angle sensor in it, make sure it's clean check power going in and coming out, it's also control your injectors pulse, better yet, try to retrieve a trouble code from ECU and go from there.
