Head Gasket
Old 11-12-06, 10:11 PM
chevyastro4x4's Avatar
Head Gasket
Would you guys\girls use a rv gasket maker with a headgasket, or just the gasket
Old 11-12-06, 11:23 PM
nap's Avatar
nap
nap is offline
New Member
Received 2 Upvotes on 2 Posts
absolutely not on the RTV sealant.
It is not designed for this type of application.
If you want to use something, copper spray-a-gasket is designed for this purpose. It will aslo add some adhesive to assist in maintaining gasket position when installing if needed.
I prefer to install dry unless the manufacturer specifically recommends an additional sealant.
remember; cleanliness is next to godliness. To assure a no-leak install the surfaces should be prepped very well. Absolutely no old gsket left over. You should also check the head and block with a straight edge to be sure no warpage is present.
It doesn;t do any good to replace a blown head gasket on a head that is warped.
Old 11-12-06, 11:42 PM
ok thanks, both the head and block are brand new, i dont see any thing in my service manual for my grand am about useing any sealant, but i hear its better to use one.
well i found this on the internet:
http://permatex.carshopinc.com/product_info.php/products_id/42287/80697
its the same as rv copper sealant, i been useing for all my seals
Old 11-14-06, 12:18 AM
O
I always use headgaskets with sealent built in like Fel-pro.
Old 11-14-06, 12:47 PM
9
many books i have used say to spray the gasket with silver/aluminum paint. has always worked for me...
Old 11-14-06, 03:59 PM
are you talking about just reg old silver/aluminum paint you paint anywhere and you wait for the paint to dry
Old 11-14-06, 09:17 PM
nap's Avatar
nap
nap is offline
New Member
That is exactly what I was speaking of.
Maybe I'm misunderstanding what you mean with "rv copper sealant"
Do you actually mean "RTV"?
If so, the RTV stuff is intended where a full bodied product is needed to fill a gap and actually as alternative to a gasket in many situaions.. Spray a gasket is intended where a very thin layer is desired. The make up of the 2 is very different.
The bottom line is; if you are going to use a gasket, let the gasket do what it was designed to do.
Old 11-14-06, 10:21 PM
im going to use a gasket but i was just woundering if it was nessaly to use a sealant with it, because the service manual says to.
Old 11-15-06, 05:21 PM
nap's Avatar
nap
nap is offline
New Member
__________________
that is the type of thing I was speaking of when I spoke of if it was recommended or required. If you use O.E.M. gaskets, I would follow those directiond to the T. If you use some other manufacturers gasket, i would tend to follow that manufacturers recommndations rather that O.E.M. directions.
Old 11-16-06, 12:15 AM
__________________
Ok Thank You
