'86 Celica Rough Idle in Drive
Old 11-14-06, 05:19 PM
When my car is in drive I'm ideling at 600-650 rpm and it's pretty rough. In park I'm at 900 (aprox) rpm and it's smooth as silk. Just changed out the plugs, wires, cap, rotor, oil change and the like. The only abnormality is the oil pressure is low except when accelerating and the plugs had white residue with a little carbonation. Car is an '86 Celica GT, FWD 2.0L 2SFE with 82,000 miles. No othe outward indications of anything wrong. No hard starts. No smoke. Just the timing I hope?!?!?!?
Old 11-14-06, 05:39 PM
HotxxxxxxxOKC's Avatar
There could be a number of things wrong.
Check your air filter
Spark plugs and wires
PCV valve
MAF sensor
MAP sensor
Idle Air Control Valve
Throttle position sensor
EGR Valve
and about 20 other things.
Old 11-14-06, 05:58 PM
Have a compression test done.
Old 11-15-06, 05:03 AM
Check your engine/trans mounts........see if any of them are sagged/broken.........Most normal people call them engine mounts.........Dealers call them "insulators" as in insulating engine vibration from the rest of the vehicle
Old 11-15-06, 06:57 AM
Motor mounts are good, so are the exhaust insulators. Getting started on the various sensors... Thanks for the replies and wish me luck!
Trackbacks are On
Pingbacks are On
Refbacks are On
