Sounds like a miss in the engine, help........................
Old 11-16-06, 04:52 AM
G
I have a 1987 Chevy Blazer 4x4, 305ci engine. The truck was running a little rough so I put in new plugs, rotor and cap. At an idle the engine seems to run smooth, when I give it gas and bring up the rpm's, the engine seems to rock a little and it sounds and feels like it's only running running on 7 cyl. If I rev the motor up and down, sometimes I'll get a back-fire. Could a bad plug wire make it run like this? Is there any way of checking the wires before I go out and buy a new set? The wires on the truck are Packers, I think these are pretty good wires, don't know how old they are. I've had the plow truck for 3 years and never changed the wires yet.
Old 11-16-06, 05:14 AM
How many miles??? Bad wires would be more likely to miss all the time. What you describe sounds more like a cam lobe worn or burned valves. Run a compression check.
Old 11-16-06, 02:20 PM
James Sanders's Avatar
if you have a multimeter measure the resistance in the wires from end to end
Old 11-16-06, 09:41 PM
R
Sound like you may have inadvertantly crossed a plug wire double check them, also pay attention to how the wires are routed, it is possible for them to crossfire , if improperly routed. Bad insulation on any wire could cause it to fire to the engine block or any other metal part at high rpm but not at idle. I would install a new set of high quality wires before assuming a more serious problem.
Old 11-17-06, 05:40 AM
G
Put on a new set of wires. I found out that the #8 plug wire was not firing, runs alot better now. Thanks for the help............
