Key stuck in the Ignition Switch
Old 11-18-06, 06:16 AM
PineCone's Avatar
Hi:
Toyota Corolla '99, a Key stuck in the Ignition Switch, that happened 'three times' for the past years. One of occurrences was just yesterday.
Each time, a Key got out/took off after applying back and forth, 'P/Park' to 'D/Drive' on Automatic Transmission.
There are three different keys, one is an original came with a Car, two are 'copies' made by a professional key maker.
Except this problem, above, '99 Corolla runs GREAT.
What causes this problem?
Ignition Switch or Transmission problem?
Thanks always, ...
Old 11-18-06, 06:30 AM
Received 821 Upvotes on 720 Posts
It is probably the transmission linkage out of adjustment. When I first got my jeep they recalled the brake rotors and transmission cable. When I got back from the dealer the key wouldn't remove because the shift lever wouldn't go far enough into park
Since the dealer did all the work on this, I'm not sure how you adjust the cable but hopefully inspecting it will show you how. Of course you could wait for someone with more brains than me to post an answer
Old 11-18-06, 06:51 AM
PineCone's Avatar
Red face
Hi:
Thanks for the quick response.
Old 11-18-06, 07:42 AM
bigfred's Avatar
Have same problem with 2003 Monte Carlo. It's problem is with the shifter not quite moving to right place when placed in park to cause the key locking solenoid to release the key. But the problem has quit before I got around to fixing it.
You might be able to get more help at automotiveforums.com and/or batauto.com That's where I found out how to fix the Monte Carlo when/if it happens again.
Good luck.
