Brake Problem
Old 11-18-06, 08:45 PM
R
Brake Problem
Hello I have A 1995 Chrysler Cirrus 6cyl w/ABS.
The other day I got in the car and took off I felt the brake pedal go all the way down. as soon as I could I check the brake fluid it was ok ,I checked the inner part of the wheels for any signs of leakage, nothing.The only other thing I thought it could be is the Master cylinder,so I changed it and bled the brakes.
Unfortunately I still have the problem,pedal goes all the way down.
Any and all help is welcome!!!
Thank you in advance!!
RC
Old 11-19-06, 05:50 AM
T
sure u got all the air out? ive seen new mastercylinders not bleed properly giving the problem you have. pain in the butt. but then again im not familiar with abs on these american cars. if it was a new imported pontiac from australia then i know them back to front.
Old 11-19-06, 06:08 AM
O
did you check and bleed all your cyclinders?
did you bleed all the cyclinders. Also ive had cyclinders leak and you could not see all it takes is a little air and bye bye brakes.
