96 Blazer Heater Switch?
Old 11-20-06, 07:46 AM
W
96 Blazer 4dr, 4x4, 4.3
The heater switch only worked on high for a while but now it won't work at all. After searching the forum here, I realize this is most likely a "resistor" problem. My question(s) are,, where is this located on the Blazer and how hard is this to get to? Does the dash cluster have to come off or am I in the wrong area all together?? Is this an expensive part and being a "somewhat novice" would I be able to do this?? Thanks in advance.
Old 11-20-06, 10:41 AM
W
Anybody??? LOL
I have a Chiltons' manual but it doesn't say ANYTHING about a resistor or the blower switch itself. Very confused???
Old 11-20-06, 02:04 PM
W
bump,,, help please.
Old 11-20-06, 02:12 PM
K
I do not know your specific model. GM normally, the resisters are mounted to the duct next to the blower motor under the hood. Approxametly 2" x 3" plate. It has a couple screws and an electrical plug. The actual resisters are inside the duct attachet to the plate. Normally the resisters are not used on high speed. Sounds more like a blower motor problem. If you can, check for voltage on the blower motor plug to ground. Auto Zone should have some help on line with photos on changing a blower motor.
Old 11-20-06, 02:14 PM
W
Under the right side of the dashyou'll see the A/C plenum. The blower motor is in the right side and gpes UP into the plenum.
The resistor block should be very close to the motor and usually is about 3 inches by 1 1/2 inch and secured by two screws.....
NOW...........If the resistor HAS taken a digger, be advised it will be in your best interests to change the motor also......or at least ohm check it......99% of resistor failures are caused by motors that are worn, not necessarily worn out........but worn
Old 11-20-06, 02:31 PM
W
When you say the right side of the dash do you mean,, "inside" the vehicle or under the hood???
