need help f-150
Old 11-24-06, 02:52 AM
W
Thumbs down need help f-150
no heat in cab and put second replacement thermostat and still cold how do i get heat
Old 11-24-06, 03:37 AM
No heat in the cab is usually not a problem with the engine thermostat, if the temp gauges registers normal. It is usually caused by malfunctioning heater control, usually vacuum operated. You could have a bad control or cracked/broken vacuum lines, or a blockage in the heater core under the dash.
