Saab 900 SE electrical problem
Old 11-25-06, 10:38 AM
I have a 1995 Saab 900 SE and when i put the car in reverse, the fuse for the reverse light blows out. I've checked the connections and light bulbs in the back and everything looks okay. Also, the windshield wiper is on the same fuse and I know thats not the problem, so the problem is definitely with the reverse light mechanism. Any suggestions?
Old 11-25-06, 12:21 PM
HotxxxxxxxOKC's Avatar
Disconnect the reverse lights, put in a new fuse, then see if it blows. If it does, then you have bad wiring somewhere on that circuit. If it does not blow, then you probably have a bad light.
