1991 Pontiac Tansport Problems
Old 11-25-06, 12:22 PM
Hi, i got a 1991 Pontiac Transport
Van will not start unless Ether is sprayed into the carb.
When started with ether car idles high for a bit then idles lower and lower untill it eventually stalls. Van is driveable 2footed, cuz itll stall if i come to a complete stop w/o my foot on the accelerator. Car will aldo stall out if the van is driven for a long period of time.
car will stall and will start back up but when u put it into drive itll sputter and stall again.
usually hafta wait 30min to an hour before u can drive it again.
can someone please help me with this problem. Ive been trying to fix this for over a year. (tried new fuel pump/filter and didnt work)
Old 11-25-06, 04:03 PM
the_tow_guy's Avatar
If you haven't checked for codes yet, I would do that first. You should be able to read the codes yourself on the GM OBD-1. Check here:
http://www.troublecodes.net/GM/
Post back what you find. I'm thinking you have a problem in the idle air control system.
