oxidation
Received 0 Votes
oxidation
hi there ,
my car has slightly oxidation on the roof . is there anything i could do to fix the problem on my own? kindly give me the procedure and the list of materials need on this process.
i really appreciate your help.
thanks,
jephoy64
thanks,
jephoy64
Oxidation is tough to remove and most often it has to be done with a professional buffer and the right compounds. If you're going to do it by hand, I'd try Meguiar's Dual Action Cleaner/Polish. Use a clean terry cloth rag and small circular motion on a spot and see how it does. You'll have to turn the rag several times, as the oxidized paint will load up the rag. Let it sit after doing a small area and completely dry out for a minute. Wipe clean and see what you get. It may be hard by hand to get it perfectly even. Follo up Meguiar's Sythetic Sealant.
Hope that helps
Hope that helps
Received 0 Votes
Hope that helps
Hope that helps
Received 0 Votes
I think tow guy and OKC are correct, the only thing I would add is when testing a "spot", make it a larger spot. Many people rub out a 2 inch diameter area and it looks great. Try it on a 12 inch area and see if it looks good and even, then evaluate fro there.
