stumped
Old 11-26-06, 05:05 PM
Question stumped
i have 1988 olds cut cira 2.8L what is the omes reading you should get when testing them i get 8.3 on one & 5.5 on the other two is that good or bad .also diying when low on gas less then 1/4 tank wile stoped at a stop sign. also surging when coasting at low speeds
Old 11-26-06, 06:34 PM
I'm not catching what you're checking with your ohm meter. As far as the fuel system problems you're having, I would change the fuel filter if it hasn't been changed in the last couple of years.
Then if you still have problems I would have the rail pressure checked. That would tell you about the condition of your fuel pump and the fuel lines and regulator.
Hope this helps,
Bob
