Test Pins Location
Old 12-02-06, 12:14 PM
Test Pins Location
Where is the "Breakout Box" that houses the test pins for engine sensor checks on a 1998 Ford Windstar 3.8L V6 ? ( particularly for test voltage readings from cam shaft position sensor)
Old 12-02-06, 12:42 PM
HotxxxxxxxOKC's Avatar
The Cam sensor goes directly into the PCM (powertrain control module) pin 85.
See if this helps.
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/3a/bb/0900823d801d3abb.jsp
Old 12-02-06, 12:52 PM
The "breakout box" you refer to is a tool that connects between the ECM and the ECM plug to allow you unrestricted acessto test wiring..........It's a handy thing to have but not absolutely necessary as you can back probe each sensor seperately
