car heater
Old 12-02-06, 09:45 PM
car heater
so my question is about my girlfriends 98 windstar for some reason the heater only comes on while she is accelarating and stop as soon as she get to speed and blows out cool air any ideas cause i am stumped
Old 12-03-06, 03:10 AM
New guy's Avatar
Check coolant level in both Radiator and resorvoir, top off as needed, sound like air trapped in the heater system, try to bleed the air out and check the coolant level again.
Old 12-03-06, 01:06 PM
ok
already did that still no heat unless you slam on the gas then when you get up to speed no heat
Old 12-03-06, 01:58 PM
HotxxxxxxxOKC's Avatar
Replace thermostat.
Old 12-03-06, 03:03 PM
Impeller on water pump may be slipping.
Old 12-03-06, 04:38 PM
^ he would probably be having overheating issues if that was the case
Old 12-04-06, 02:32 AM
New guy's Avatar
What engine is in your windstar, 3.8 Ford or 3.3 Nissan?.
I do not know about Ford's but if it's Nissan engine, you are having air pocket in the system, bleeding air out of the Nissan engine does needs a little trick to do, otherwise the air will not comes out.
Old 12-04-06, 07:05 AM
Cool air
Check the coolant level in rad when cold as if lo you will not get any heat at idle , then you may have to find where the coolant went, some
loss from evaporation is normal but most service centers top up coolant with regular servicing.
