bypass tube
Received 0 Votes
99 ford windstar 3.8 tried to replace camshaft sensor but bypass tube in the way i tried to remove tube ,not budgin so i tap tube with screwdrvr above weld and under same at bracker hold bolt. Bad idea, leaks pretty good. bought some jb weld and some quicksteel .My ? is should I use these products or should just get a new one at dealer.Also what is a good way to get tube out ,it is stuck good rusted
JB Weld products work great. My mother in-laws motor is practically held in by JB Weld. Could answer your other questions though. Try spraying some WD40, etc around it?
