masda 93 b2600i lack of accelration
Old 12-03-06, 02:35 PM
Unhappy masda 93 b2600i lack of accelration
Hi I have tryed everthing changed wire,cap and roter ,bath filters even the air flow thing the book is limited . when you step on the gas it boges out
do it slowley and it will rev up to drive you have to run it as amaual auto matic over drive on flats no hill won't keep work great at 139 k and over
need help even the masda deler has no ideas
Old 12-03-06, 02:46 PM
HotxxxxxxxOKC's Avatar
Hard to understand what you are saying, but, you are just saying the engine bogs down when applying gas?
Does it do that when in neutral and hitting the gas?
There are numerous possibilities:
1. PCV valve
2. Transmission
3. Cat (exhaust blockage)
4. MAP sensor
5. MAF sensor
6. Throttle position sensor
7. Fuel pump
Start with the PCV valve since it's the cheapest part in the list.
Old 12-03-06, 03:00 PM
Any lights lit(codes set)??? My guess would be a bad cat, as suggested above.
Old 12-03-06, 03:31 PM
thanhs for the come back
I put on a new cap 4 year ago to cert tryed removed the cat still bog
fuel good
check light can on at 80,000 k for oil change switch wire bog strarted
will try
trany good draws when engen runs well some times cold
4. MAP sensor
5. MAF sensor
here I go again
Old 12-03-06, 04:35 PM
Wow, it's hard to understand what you are saying. Good luck anyways.
