Cavalier will not start
Old 12-09-06, 10:22 AM
I have a 2003 cavaleir that won't start. It has been very cold the last couple of nights. This morning it was started and left to warm up. When I went back outside it had gone dead and would not start again. The engine turns over fine but won't start. I got an engine scaner and plugged it in and it gave a code of p0440 EVAP emmission control system malfunction. Can you give me some idea of what I need to do? I've been told everything from fuel pump, cracked vaccum lines, or fuel filter. thanks
Old 12-09-06, 10:50 AM
HotxxxxxxxOKC's Avatar
EVAP codes are usually the cause of a lose or missing gas cap. I don't see this code preventing you from starting, but it might. Check your gas cap. Have Autozone or a place like that test your battery and alternator.
Old 12-09-06, 10:59 AM
moisture
Could it be posible for moiture in the tank freezing and causing a blockage in the tank or line/filter?
Old 12-09-06, 11:36 AM
two evap codes
The scan shows two p0440 evap codes. One would be a missing gas cap. I just learned it has been gone for about two weeks. Any idea how this would effect any other emissions that would prevent it from starting?
Old 12-09-06, 03:55 PM
Read this article about EVAP systems.
http://web.bsu.edu/tti/5_1/5_1e/5_1e.htm
Trackbacks are On
Pingbacks are On
Refbacks are On
